I was thinking about writing my own program, maybe another GUI for DVD Author. I don't know anything about programming though, where should I look or who should I talk to to get started?
Thanks,
Garibaldi
What language have you considered? There are several that are fairly intuitive, like flavors of Visual Basic and VB.bin.
When I learned VB the first time I used the self-tutorial that came with the VB package. It consisted of lessons and tests. It was a fast-track to learning VB. I recommend that course.
The next level wou;d probably be buying course material from a third party for self-study.
Then you have a course at the local community college, or a training center that caters to businesses in the area. Most offer accelerated courses in programming.
Good luck, Garibaldi
I would recommend VB.NET or C#
So Cap, it sounds like Visual Basic and VB.bin are probably the easiest. Where could I download either of them to get started? Are there some on-line tutorials besides the one included?What language have you considered? There are several that are fairly intuitive, like flavors of Visual Basic and VB.bin.
I was just looking around at download.com and found this:
http://www.download.com/NetXP/3000-2...ml?tag=lst-0-3
Would this be useful for me once I get Visual Basic, since a GUI might be an easier start?
Looks good. You definitely want that, but I think you ought to try it before you use add-ons.Originally Posted by Garibaldi
I mis-typed. It's VB.NET like Stilt mentioned. I don't believe it's freeware. I think it's a purchase-only, but if I'm wrong someone will correct me here. VB is soooo easy to learn.
I'll see if i can find the link, but there was a way to download VB.Net free from M$.
Nothing can stop me now, 'cause I don't care anymore.
how to author a DVD from the beginning to the end
By michcio in forum User guidesReplies: 3Last Post: 13th Apr 2012, 17:43 -
How can I write something at the beginning and the ending of the subtitle?
By dsajkw in forum SubtitleReplies: 3Last Post: 21st Oct 2009, 04:53 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum CapturingReplies: 5Last Post: 15th Oct 2009, 16:51 -
Green frame at beginning of video, Why???
By Hittz in forum Newbie / General discussionsReplies: 9Last Post: 19th Dec 2008, 21:13 -
In the Beginning was the Command Line
By ahhaa in forum ComputerReplies: 2Last Post: 9th Oct 2008, 11:04
