I want to convert my bands DV into DVD, and edit out some useless footage. Ive looked at a few programs, and even ones which say are straight forward are a apin in the ass to use.
Whic one would you say is the most straightforward for someone who isnt very good on computers?
Im used to using dvd shrink/nero for burning dvds, but how do i burn my edited footage? I have no idea.
Could you email me if you can help?
azaslade@hotmail.com
Cheers
Virtualdub is pretty easy, lots of options and free.
Windows Movie Maker or Ulead's VideoStudio are probably the easiest, although not as powerful as the big boys. If you need something cheap and cheerful, Movie Maker is free if you have XP, otherwise VideoStudio is cheap.
VirtualDub is not intuative as an editor, although it can be used to cut and join. I'd leave it until you are more experienced.
What Is The Easiest Video Editing Software For Beginners That's Free?
By Joshua P in forum Newbie / General discussionsReplies: 17Last Post: 9th Jul 2011, 10:00 -
Whas is the Easiest to Use DVD Ripping Program?
By Gatimo in forum DVD RippingReplies: 4Last Post: 13th Jan 2010, 21:23 -
Easiest Cutting Program?
By Merkaba188 in forum EditingReplies: 9Last Post: 4th Nov 2009, 21:25 -
Easiest Program To Merge Two DVDs Without Interruption
By V Bot in forum DVD RippingReplies: 7Last Post: 11th Sep 2009, 21:27 -
What is the easiest program to convert MKV to AVI (without audio)
By Mylo in forum Video ConversionReplies: 2Last Post: 22nd May 2009, 16:52
Statistics
Newest guides
Latest tool updates
New media comments
