hello everyone is there anyway of recording live video stream from the net![]()
Results 1 to 10 of 10
Thread: live video stream
one problem solved can solve alot of problems
you can try camstudio
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
thanks alot mate will give it a try
Thanks glock. I was trying to think of the name of the app because I wanted to try it myselfOriginally Posted by glockjs
np maghera
i had trouble too all i remembered that it was in the how to capture winamp visuals guide. so i went back and looked it up
i tried to use it before but thats when i had my celeron 1.1 with really slow ram and small hdd
it seems like it would work pretty good. have an ok system now so ill have to give it another go.
After I saw maghera's post I went into tools and poked around with no luck. Then I came back here and voila! The Sessy Bish had listed it
I'm downloading it now
Edit: DOH! It doesn't work on my Win2K laptop. Every time I try to capture it says "Error creating AVI file". Nothing helps. I'll try it on my XP desktop tomorrow.
i cant get it to capture streaming video only audio,anyone else with the same problem
it should basically capture anything that going on on your desktop. try playing with the settings. im at work right now, i'll try when i get home. or maybe cap can assist on this one.
If something you're trying to cap is using overlays, it'll just capture a blank. Go into Windows Media Player or whatever app and turn off overlays, under options, performance, advanced button. That's the usual problem with a blank capture..Originally Posted by maghera
Alan
thanks alot everyone got problem sorted,just turned of overlays on windows media player.
cheersone problem solved can solve alot of problems
Accepting a Live Video Stream as input
By jay.kert in forum Video StreamingReplies: 0Last Post: 22nd Oct 2011, 13:31 -
How to Stream Live Video from a Subscription??? PLEASE HELP!!!
By fcukinyahoo in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2011, 14:14 -
Cache Live Video Stream
By Algernon62 in forum Video StreamingReplies: 0Last Post: 5th Apr 2011, 13:46 -
How to stream live tv or video with VLC/videolan
By Baldrick in forum User guidesReplies: 19Last Post: 17th Dec 2010, 01:49 -
How: Converting incoming video file into live stream?
By 2Blive in forum Video StreamingReplies: 0Last Post: 14th Nov 2009, 13:00
