VideoHelp.com Forum
  1. I've owned a Sony DRU-540A for about three months and it's always worked great with XP SP1 and Nero. I decided to format my computer last weekend and reinstalled using XP SP2. Everything installed perfectly. However, my Sony DRU-540A doesn't appear to want to burn any discs (CDR or DVDR) despite the fact that it can read both formats perfectly. I ran DiscCheck, and it shows that my CD-R Write Speed is 0x and DVD+R Write Speed is 0x. Also, I tried upgrading the Firmware from 1.0a to 1.0b but this didn't make a different. I've checked Google and the forums and haven't found anyone that is having a similar problem. Any suggestions what I should try next to get my burner working again? I want to make formatting and installing XP SP1 as my last resort.
  2. I am having a similar problem under XP SP2.
    drive = Sony DRU-500ax
    Firmware = 2.0h
    Anytime I would try to burn data to a DVD it would fail in Nero. I've had XP2 for 3 or 4 weeks but prior to today I'd never burned a data DVD nor used Nero to burn any video DVDs. I've been using TMPGEnc's products for DVD authoring and burning without problems on XP2 so far.
    I started with Nero v6.3.1.25 - the most up-to-date version that I know of. It wouldn't burn data to a blank DVD at 4x. I didn't try burning at a slower speed because the media is 4x and should work at 4x - just like it does when I burn using other software on my system.
    I upgraded the 500AX's firmware to 2.1a - prior to this the windows device manager and Nero's info tool displayed this drive as being in PIO mode only even though 'use DMA if available' was selected. After the 2.1a firmware upgrade it's listed as DMA on, and that's the only step forward I've made.
    Nero 63125 still wouldn't burn a data DVD at 4x. I uninstalled and downgraded Nero to v6.3.0.2 hoping that would change something. I don't think it did. I still can't burn a data DVD using Nero at 4x on 4x media. I can burn at 2.4x, but I'm really not happy as there's a big difference between 20+minutes per disc and 12 minutes per disc when you want to burn off about 40GB worth of stuff to free up space on a hard drive for future projects. I'm not burning from ISO images but I think I may try that... make an ISO from my files using Alcohol or something and then burn using BlindWrite... at 4x. I have multiple hard drives and it doesn't take much more than a minute for me to make an ISO image if I manage the data right.
    I don't know if this helps anyone - but maybe at least try burning at a slower speed first before changing software and firmware. All my upgrading and downgrading were for nothing apparently and I'll just have to wait and see if Ahead can fix Nero in a later release... since other apps will burn to DVD at full speed on my system I can't blame this on SP2 IMO.
    I even tried a laser cleaning disc for cryin out loud :/ Some errors from my Nero logs - #3 is copied from the 2.4x successful burn log in the same area where the errors are in the other logs. #1=Nero63125@4x, #2=Nero6302@4x, #3=Nero6302@2.4x.
    #1
    7:30:25 PM #18 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 12:26,712 (746712ms) -> OK
    7:30:25 PM #19 Text 0 File DVDPlusRW.cpp, Line 564
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    7:32:27 PM #20 SCSI -1106 File Cdrdrv.cpp, Line 1431
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x03A10000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x73
    Sense Qual: 0x03
    CDB Data: 0x2A 0x00 0x00 0x00 0x08 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
    Sense Data: 0xF1 0x00 0x03 0xFF 0xFD 0x00 0x00 0x12
    0x00 0x00 0x00 0x00 0x73 0x03
    7:32:27 PM #21 CDR -1106 File Writer.cpp, Line 301
    Power calibration error
    7:32:27 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
    all writers idle, stopping conversion
    7:32:27 PM #23 Text 0 File ThreadedTransfer.cpp, Line 223
    conversion idle, stopping reader
    7:32:27 PM #24 Phase 127 File dlgbrnst.cpp, Line 1800
    Generating DVD high compatibility borders
    7:32:28 PM #25 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 0:00,000 (0ms) -> OK
    7:32:28 PM #26 Phase 129 File dlgbrnst.cpp, Line 1800
    Generating DVD borders completed successfully
    7:32:28 PM #27 Text 0 File dlgbrnst.cpp, Line 1658
    7:32:28 PM #28 Phase 38 File dlgbrnst.cpp, Line 1800
    Burn process failed at 4x (5,520 KB/s)
    #2
    8:00:35 PM #18 Text 0 File dlgbrnst.cpp, Line 1658
    8:00:35 PM #19 Text 0 File DVDPlusRW.cpp, Line 564
    8:02:35 PM #20 SCSI -1106 File Cdrdrv.cpp, Line 1431
    SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x02FF0000
    Sense Code: 0x73
    Sense Qual: 0x03
    8:02:35 PM #21 CDR -1106 File Writer.cpp, Line 301
    8:02:36 PM #22 Text 0 File ThreadedTransfer.cpp, Line 229
    8:02:36 PM #23 Text 0 File ThreadedTransfer.cpp, Line 223
    8:02:36 PM #24 Phase 127 File dlgbrnst.cpp, Line 1800
    8:02:36 PM #25 Text 0 File dlgbrnst.cpp, Line 1658
    8:02:36 PM #26 Phase 129 File dlgbrnst.cpp, Line 1800
    8:02:36 PM #27 Text 0 File dlgbrnst.cpp, Line 1658
    8:02:36 PM #28 Phase 38 File dlgbrnst.cpp, Line 1800
    #3
    8:07:33 PM #18 Text 0 File dlgbrnst.cpp, Line 1658
    Set remaining time: 20:41,187 (1241187ms) -> OK
    8:07:33 PM #19 Text 0 File DVDPlusRW.cpp, Line 564
    8:27:29 PM #20 Text 0 File WriterStatus.cpp, Line 115
    <SONY DVD RW DRU-500A > start writing Lead-Out at LBA 1978768 (1E3190h), lenght 0 blocks
    8:27:29 PM #21 Text 0 File ThreadedTransfer.cpp, Line 229
    8:27:58 PM #22 Text 0 File dlgbrnst.cpp, Line 1658
    8:27:58 PM #23 Text 0 File dlgbrnst.cpp, Line 1658
    8:27:58 PM #24 Phase 37 File dlgbrnst.cpp, Line 1800
    Burn process completed successfully at 2.4x (3,312 KB/s)
    I also ran Nero CD-DVD Speed on the disc I burned. See attached image... looks good to me.
  3. The image I thought would attach to the above post :/
  4. Member modtang's Avatar
    disregard
  1. Replies: 3
    Last Post: 13th Jan 2011, 11:42
  2. Why have my TV speakers stopped working?
    By jimbo7777 in forum Audio
    Last Post: 17th Apr 2010, 18:19
  3. Replies: 0
    Last Post: 27th Oct 2009, 14:47
  4. SVC2DVD quit working on VISTA SP2
    By artar in forum SVCD2DVD & VOB2MPG
    Last Post: 25th Aug 2009, 17:01
  5. SVCD2DVD 2.5.5030 Not Working with Vista SP2
    By k_vic in forum SVCD2DVD & VOB2MPG
    Last Post: 28th May 2009, 12:33
