VideoHelp.com Forum
  1. Member Wile_E's Avatar
    I'm trying out WinDV to capture tapes from my ADVC-300. It keeps splitting the file up. Is there no option to create one huge AVI file? I have WinXP, and NTFS partition, so no 4GB limit here.
  2. Member daamon's Avatar
    Hi Wile_E,
    Sorry - can't help on that one, but if it turns out it doesn't then maybe DVIO, AVI_IO or Scenalyzer Live will do the job...
    I'm not sure, but VitrualDub may also do the trick - I'm not sure if it captures DV (which I believe your ADVC inputs to the PC).
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member Wile_E's Avatar
    Oops...Just checked the WinDV settings. It has option to set AVI size up to 1000000 frames. That should be good for at least 8-9 hours recording, I think.
  1. WinDV - Hear sound during capture?
    By scormodo in forum Capturing
    Last Post: 20th Mar 2010, 10:41
  2. Replies: 11
    Last Post: 18th Oct 2009, 08:52
  3. Replies: 3
    Last Post: 5th May 2009, 05:48
  4. WinDV - Stop capture at tape end?
    By stantheman1976 in forum Capturing
    Last Post: 18th Jan 2009, 20:03
  5. Skipping in beginning of WinDV capture
    By rjack in forum Capturing
    Last Post: 10th Jan 2009, 22:16
