VideoHelp.com Forum
  1. Member Wile_E's Avatar
    I'm doing analog to DV capture using Sony Vegas Movie Studio, and a Canopus ADVC-300. I get some dropped frames sometimes.
    I was recommended to try WinDV free capture program because it has a buffer. It works, but I'm concerned if there are any quality differences between capture programs? Once my Canopus ADVC-300 converts the signal to DV, does it matter what program you use to capture?
    not really... unless you are converting it to another codec on the fly.
  3. Member Wile_E's Avatar
    okay thanks. So the capture software doesn't really do anything with the video stream data, except converting it to an AVI file.
    If I understand it correctly, your actually just 'transferring' a type 2 DV file onto your harddrive with a .avi header (or container). There is really no 'conversion' happening. Unless you use something like iuvcr and set the codec to .mjpeg for example. read up a bit and youll understand...
  1. Replies: 21
    Last Post: 29th Mar 2012, 12:59
  2. DVREX-M1, app suddenly crashing while capturing
    By hazzmat in forum Capturing
    Last Post: 30th Apr 2010, 21:01
  3. Pictures Quality in which app?
    By eliqush in forum Editing
    Last Post: 16th Sep 2009, 11:12
  4. DV capturing app that can...
    By tangnanya in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 4th Aug 2007, 09:48
  5. Tiny TV Capturing Enhancement App for PC
    By Soopafresh in forum DVB / HDTV
    Last Post: 12th May 2007, 17:33
