What hardware do I need to capture from VHS?
From what I understand...
I need a capturing device...
And a scart socket connector/convertor to SVideo.
And that's all I need?
(Anything else?)
I'm confused, because there seems to be a plethora of hardware available!
Am I OK to get by using something as simple as the lowest Hauppauge TV cards?
Or do I need something of a higher spec?
(Do the higher spec TV cards come with extra hardware tha make them better because they can convert to MPG on the fly?)
And what about these other hardware devices that say that they are just for converting from VHS to digital?
Would these hardware be better than a TV card??
I've tried searching this website and google... but am still int he dark.
ANy help would be appreciated.
Thanks.
Jam
How much do you want to spend? Obvously the more you spend the better the results that you can expect.
Personally I use a DVD recorder."Art is making something out of nothing and selling it." - Frank Zappa
Personally, if you are going the PC approach, then I would go with an ADVC-100 or an ATI AIW Radeon card.
If you don't want to capture to the PC, go with a DVD-Recorder.
Either weay you go, you might also need a TBC(time base corrector) depending on the age of the VHS tape and if the A/V sync is off.
Do a forum search on these topics/items and you'll find others have been going through the same dilemma.
Some software/hardware to consider:
http://www.digitalfaq.com/newbiesguide.htmAnswers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
1gb of RD-RAM? You might want to change that recommendation, RD-RAM has been outdated for well over a year...Originally Posted by lordsmurfYour base? Well, they belong to me now...
I have the same question also.
I have a fairly new machine (P4 3.2, 9700 PRO, and 1 GIG DDR Ram)
I need to capture video from my VHS VCR and possible from my DVD player onto my computer. I want the target file on my computer to be in mpg or mpeg format, and about 600 megs or so in size. (So they can fit on a single CD-R)
Any suggestions? Budget isnt all that high. Im not looking to create professional video clips, because the source media isnt perfect.
Id rather buy a capture card than a new All In Wonder Video Card.
Any suggestions?
Thanks!
I use the ASUS TV/Capture card to capture files from Hi-8 and VHS with good results. PowerVCR is bundled with it and you can customize the profile to make it fit - I can capture an hour in about 640 meg at VCD rates. The sync problem with PowerVCR is now easily corrected with the VideoRedo editor. Or you could use WinDVR to capture.
-infotech
Hardly. It's still in use.Originally Posted by studtrooperAnswers to Common Video Questions:
best capture hardware and best results for capturing video 8 and later VHS
By mayhampixi in forum CapturingReplies: 2Last Post: 4th Jun 2011, 21:51 -
VHS capture hardware (again)
By ccooper in forum CapturingReplies: 37Last Post: 25th Nov 2009, 13:25 -
By Tom` in forum CapturingReplies: 12Last Post: 16th Jun 2009, 15:42 -
Capture 8mm/VHS > DV, recommendations for hardware
By nutshellml in forum CapturingReplies: 4Last Post: 21st Mar 2008, 21:07 -
best hardware + s'ware for bulk vhs to file capture & archiving
By miamicanes in forum CapturingReplies: 3Last Post: 8th Sep 2007, 20:05
