I'm looking into replacing my cpu, mobo, and ram, but I don't want to reformat my master hdd.
Is it possible to just replace my parts and hook everything back up and it'll work fine?
Possible, but windows has a strange way of never really being the same.
If you are gonna try it remember to load all the new drives and run a good registry cleaner of some sort when your done.
You can try it, nothing really to lose, but I would agree with Flaystus that you may have some problems from files remaining on the drive.
I have done it a couple of times, but ended up reformatting anyway. I'm guessing some stuff remained in the registry that the new setup didn't like.
The other benefit of a reformat is getting rid of all the hidden crap that accumulates on your HD after a period of use.
Wait... if you on this site you should have a method of backup for your important files? why not just backup and format?
Yes if you're running XP and follow the instructions I posted HEREIs it possible to just replace my parts and hook everything back up and it'll work fine?
Getting all new hardware is a very good excuse to reformat your hard drive. Completely reformatting a drive should be done once a year or so to check the drive for errors and fix them is possible. Back up what data you need and then do a clean reinstall of your OS when you put together the new computer.
FB-DIMM are the real cause of global warming
Might be better if you told us what computer you have & what computer you want.
The computer I have is in the 'computer details' and I'm looking to move up to a AMD Athlon XP3200, MSI K7N2 Delta2, 1gb 3200ddr.
Ram recommendation for amd cpu & biostar mobo combo?
By Stealth3si in forum ComputerReplies: 27Last Post: 11th Feb 2012, 12:05 -
Upgrade Celeron 2.6 socket 478 & mobo
By kenmo in forum ComputerReplies: 2Last Post: 6th Jul 2010, 21:29 -
.avi to .VOB format - without changing size & quolity
By akakiami in forum Video ConversionReplies: 5Last Post: 19th Dec 2009, 11:48 -
What format for VHS to HDD to TV? Playing off a HDD instead of DVD?
By Rudyard in forum Video ConversionReplies: 10Last Post: 6th Aug 2009, 19:46 -
Swapped out mobo & cpu...
By kenmo in forum ComputerReplies: 7Last Post: 5th Apr 2009, 01:50
