VideoHelp.com Forum
  1. Hello everyone
    I wonder is there any good HARDWARE that converts from VCD to DVD. Please note that I am not looking for the software. I know software co do that, but I am looking for a HARDWARE. Thanks for any help.
  2. Member yoda313's Avatar
    Hello,
    Well one option would be to get a settop dvd recorder and hook it up to a dvd player (one that plays vcds, most do). Then just dub like you would a video tape.
    Kevin
  3. I agree with Yoda's suggestion.
    I don't think you're going to be able to find a magic hardware box with "VCD" inputs and "DVD" outputs, since it's a complicated process. But there are numerous ways you could do it with hardware, the one with the least amount of fuss would probably be Yoda's suggestion.
    Software is another option. There are numerous techniques for achieving that conversion.
    Yoda's is What I was going to suggest too.
    Same process works for PAL to NTSC and
    SVCD/VCD to DVD and slide shows
    My Apex plays NTSC & PAL with outputs to either or auto if I had a TV that handled both.
    So I can play my (S)VCDs/PAL there and re-record on my Standalone DVD Recorder into NTSC, Finalize and done or Rip and re-author.
    In Fact I have 3 PAL Discs loaded into the Apex now, to start processing tonight.
    I can play slide shows of JPEGs and record that if I don't want to play with S/S software.
    Cheers
    RT
  1. Convert S-VHS output to VGA Hardware Question
    By videomont in forum Video Conversion
    Last Post: 10th Jan 2011, 17:07
  2. Hardware needed to convert MKV to AVI and dvd etc quicker?
    By spunge85 in forum Video Conversion
    Last Post: 16th Jan 2010, 06:40
  3. Convert 16:9 to 16:10 with letterboxing hardware
    By JesterMania in forum Media Center PC / MediaCenters
    Last Post: 27th Dec 2009, 14:29
  4. General Guidance and Hardware req. for making VCD with Digital Camera
    By dpilot83 in forum Newbie / General discussions
    Last Post: 11th Jun 2007, 05:53
  5. Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
    By scratchman in forum User guides
    Last Post: 4th Jun 2007, 01:36
