Colour video was slowly introduced into broadcast. It was therefore necessary to make it compatible with black and white receivers and to design colour receivers or televisions to be able to receive black and white programming as well. In order to accommodate the extra information needed for colour the b&w’s 30 frame/second rate was slowed to 29.97 f/s for colour. Although usually not an issue for non broadcast applications, in broadcast, the small difference between real time (or the wall clock) and the time registered on the video can be problematic. Over a period of 1 hour (SMPTE) the video will be 3.6 seconds or 108 extra frames longer in relation to the wall clock. To overcome this discrepancy drop frame is used.
Drop frame: Every frame :00 & :01 are dropped for each minute change (60 X 2 = 120) except for minutes with 0’s (00:, 10:, 20:, 30:, 40: & 50(6 X 2 = 12, 120 - 12 = 108)
Results 1 to 1 of 1
Thread: DROP FRAME
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 05:22 -
How can you tell if an MPEG-2 is drop-frame or non drop-frame?
By jlietz in forum Newbie / General discussionsReplies: 5Last Post: 3rd Apr 2007, 11:38 -
AVID Projects: Non-Drop to Drop Frame
By scottrwn98 in forum EditingReplies: 5Last Post: 6th Dec 2005, 16:02 -
Help with NTSC drop frame/non drop frame subtitles
By rogue in forum Authoring (DVD)Replies: 0Last Post: 27th Mar 2004, 08:05 -
frame drop
By kenx in forum CapturingReplies: 0Last Post: 3rd May 2002, 23:27
