Can you explain your reply? I don't know what DirectShowSource is or how to use it, and it doesn't seem to be documented in the mkvtoolnix notes. I'm on OS X, and it looks like DirectShowSource is a Windows command/program? I can extract the files from the .mkv just fine using mkvextract; I just need to know what extensions to give them so that they can be read & packaged into another format, or is there a optional command to have the extensions given automatically?Originally Posted by johns0
Results 31 to 38 of 38
Thread: How to convert MKV to Divx
That is the loading statement for an avisynth script. Avisynth is a powerful script driven frameserver that is available in the windows environment, although I believe it can be made to function using Wine or similar.
I did convert MKV 2 Xvid which would be able to play in my divx player with just using MeGUI.
Its fantastic stuff
When I run mkvextract_gui, it gives me this
"The extraction of video tracks is only supported for RealVideo (CodecID: V_REAL/RVxx) and AVI compatibility tracks (CodecID: V_MS/VFW/FOURCC). The track 1 will be skipped.
Hi all
I have been away from the hardcore conversions some years now. I'm an oldie from the heydays when you did SVCD's and VCD's from DVD's to play on your standalone player. Because you couldn't afford a DVD burner
I have lately seen this Matroska (MKV) container and I don't like it
I will be able to use my standalone DVD/DIVX player for my scattered downloaded stuff.
I started with this thread and have come to the conclution that I only need two tools.
MKVextractGUI with MKVtoolnix and AVIMux_GUI to be able to convert my mkv files so that they will be playable on my standalone player. The avi file inside the MKV container was allready a Four CC Xvid and the audio is 192kb AC3 which AVIMux apparently takes care of.
Maybe I get into trouble with some other MKV files but so far I have good and fast results with just these two GUI softwares. No sync problems with audio.
Your milage may vary but this was my 2cents.
Cheers // Radioman
im having a problem when i extract the subtitles video and audio all i get is a .ass file instead of 3 icons can u help me?
26th Jan 2010 21:10Banned
removed due to old thread.
Last edited by JeetDivX; 17th Mar 2010 at 16:46. Reason: compliance with moderator
Please don't dig up old threads. One more and bye bye.
Convert *.mkv to *.DivX
By Frizze in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2011, 23:35 -
How to Convert a MKV to DivX Ultra
By Shishir in forum Video ConversionReplies: 13Last Post: 1st Aug 2009, 06:34 -
Convert MKV to AVI or DIVX
By ranosb in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 21:59 -
i have some mkv vedio and i want to convert it to .divx
By The1One in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2008, 12:07 -
how to convert mkv to divx/avi without loosing its quality?
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2007, 11:00
