VideoHelp.com Forum
Results 1 to 12 of 12
  1. Member Sifaga's Avatar
    I have my DV file (AVI) and its 8gig , I want to save it across 2 DVD's, how can i do it so i dont have any problems restoring it later.
    thankyou
  2. Member shelbyGT's Avatar
    I use Roxio Creator and it automatically will split the file over two discs for you. When you later want to restore it to one, it will do that for you as well, seamlessly. I did this with a 7 gig file and it worked perfectly. I, however, don't know of any free programs that will do the same thing.
  3. Member Sifaga's Avatar
    Thankyou
    I'll check out Roxio Creator
    I wonder if the burner software i have do this sought of thing, i will try them out.
    ANyone know for certain if they do
    I have
    Nero
    RecordNow
    DVDDecypter
  4. Member shelbyGT's Avatar
    that's what it will look like. When you insert one of the dvd's roxio's "restore" program or whatever it is called will ask you if you want to basically reattach the file together.
  5. Member Sifaga's Avatar
    is there some other program that can do this
  6. You could eithe zip or rar it into smaller files then add to each disk.
    Not bothered by small problems...
    Spend a night alone with a mosquito
    Any backup program should be able to do this. If you have the Nero suite there is a backup program included.
    I don't have a bad attitude...
    Life has a bad attitude!
  8. Hello Ladies stiltman's Avatar
    This would me my options also, but I would use rar at store with recovery record
    Originally Posted by jagabo
  9. Member Sifaga's Avatar
    cheers for the replies
    i had a closer look at NERO and tried out its BackItUp
    it did what i wanted, spanned my file across 2 disks.
    but it converts it to some backup type files, Im going to have to see how easy it is to restore.
    i was hoping it would just cut the file in half back up the 2 halves
    Sorry, all backup programs do that. It won't be a problem restoring though, unless the discs become damaged in some way.
    I would use grade A media for anything important, but that has nothing to do with the backup software.
  11. Member Sifaga's Avatar
    Thanks Leebo,
    Its doing what i want it to do so i will use it that way
  12. I've never done it, but you should be able to cut your video in half yourself with an editing program and rejoin them later with the same program. I think TMPGenc will do it without reencoding and I've noticed some programs in the tools section that may do this. That would give you the options of cutting where you want.
    If it works, don't fix it.
  1. Span multiple discs with video?
    By kruuth in forum Newbie / General discussions
    Last Post: 27th Mar 2011, 09:56
  2. Replies: 0
    Last Post: 13th Jan 2011, 22:27
  3. Backing up a DVD
    By kschwi in forum DVD Ripping
    Last Post: 29th Nov 2009, 09:15
  4. Replies: 1
    Last Post: 7th Jul 2008, 10:50
  5. Replies: 15
    Last Post: 20th May 2008, 16:49
