VideoHelp.com Forum
  1. I had a few movies in MPEG format, and I used SVCD2DVD to author a DVD of them. After burning the disc, I can play it in my DVD player but can't hear anything. On the computer, however, the music is just fine. It's weird because when I burn images of DVD discs, I can hear the music on both the computer and the DVD player, so the problem is not with either of them.
    One thing I should note is that after authoring the DVD with the program, the AUDIO_TS folder was empty. Is this a problem? Maybe I should just author the DVD with different configurations, here is an image with the options I use so you can see if something is wrong:
    Many thanks,
    Chen
  2. Member daamon's Avatar
    Hi Chen,
    The answer to your question may be in the software you use - read all the wording in the "Mpeg audio re-sampler/encoder" section...
    As for the AUDIO_TS folder being empty - this is fine / normal. It's a relic from the DVD structure when audio DVDs were made (or something like that). It's kept because some DVD players look for both folders to identify a disc as a DVD. Without it, it might not play even though it's empty.
    Good luck.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  1. help,, for burning a dvd movie and player at sony dvd player.
    By flowerhorn in forum Newbie / General discussions
    Last Post: 28th May 2008, 09:12
  2. Burning AVI file to DVD-RW to play on a Divx DVD player
    By Jay8284 in forum Authoring (DVD)
    Last Post: 5th Jan 2008, 14:03
  3. Only hear sound if I use Nero Player how come.
    By andersonmilltexas in forum Newbie / General discussions
    Last Post: 21st Dec 2007, 22:48
  4. Replies: 1
    Last Post: 11th Dec 2007, 00:53
  5. Capturing a dvd movie problem - can't see or hear anything!!!
    By dziendobry in forum Newbie / General discussions
    Last Post: 20th Sep 2007, 14:08
