VideoHelp.com Forum
Results 1 to 9 of 9
Thread: unknown device?
    those little yellow question marks in computer mgmt are getting on my nerve, anyway to find out what device it is so i can look for a driver, is there a program for that..anything at all i can do to fix this..holla back plz
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  2. Member Dr. DOS's Avatar
    Download AIDA32 .... it is a sweet progam that will tell you everything you have in your machine
    Also, what section are they under? Give us a screen shot.
    here is that screen shot yall wanted....
    let me know whats best
    also is there like a huge virus or somehtting out there that can disable hardware..it sounds stupis but alot of my stuff doesbn't seem to be working, when i cut on my external harddrives they dont pick up, beacause my usb 2.0 card cant be found, and when i uninstall and reinstall things in computer mgmt, its like the drivers are allready there for the things that i uninstalled....also my built in ethernet card wont pick up, i had to buy another one recently, cause its just like the hardware has just stopped working..holla back
  5. Hello Ladies stiltman's Avatar
    screen pict is of your non working USB card
    also click view hidden devices and check to see if there are others.
    download the latest drivers for you USB card
    delete the unknow devices (all of them before you reboot)
    reinstall them with the latest drivers (not the installed ones on your computer)
    Originally Posted by jagabo
    no its not, the usb card still isn't taking thed river off the software that came with it, i think it should take that first of all
    Suggest boot to safe mode, then remove the unknow devices, then reboot and reinstall drivers
  8. Member Dr. DOS's Avatar
    Hmmm...
    SIRCOOKS, is this by chance a FASSCOM MB? Some of the components look familiar. If it is, XP did not recognize the USB, Video or Audio components built into the unit I have. It required loading the drivers via CD that came with the MB
    no its a foxconn mobo, is that what your trying to say
  1. Replies: 5
    Last Post: 20th Nov 2010, 13:40
  2. unknown device missing
    By alintatoc in forum Computer
    Last Post: 27th Oct 2009, 01:26
  3. 4g USB Thumb Drive - Unknown Device ???
    By blinky88 in forum Computer
    Last Post: 24th Aug 2009, 02:35
  4. Replies: 9
    Last Post: 16th Aug 2009, 17:22
  5. Trying to locate a device in Device Manager
    By alegator in forum Computer
    Last Post: 13th May 2009, 10:53
