ok, couple of questions and comments on this player.
first of, great machine, has played damn near everything i have thrown at it,so far about 4-5 no plays out of about 100, 3 due to qpel and two unknown reasons.
has anyone had a prob with memorex dvd-r 4x, i had 6 discs burnt of that media, two played fine, and the other 4 sounded like they were scraping in the maching during load, then 90% of the time those 4 would just have the cd tray re-open without loading. i burnt those 4 movies onto a different dvd-r media and they worked perfectly. so maybe a prob with memorex dvd-r?
also i found that divx files joined with project divx, did not play sound, the unmerged files played fine, and after just doing a quick save as avi in virtual dub, they worked fine
having a few problems trying re-encode the qpel files, when i tried dr divx, they loaded and played, audio was good, but the video was very choppy, like it was misssing every other frame
so i tried virtual dub, but when i load the avi i get error loading frame 0 and then it wont let me do anything.
i searched for days on these forums trying to find a solution that seems to work and have yet to find one, so if anyone has a proven method, please help.
also what causes audio to keep cutting in and out and getting out of sync i have two videos that do this.
i suppose thats all for now
thanks for any help anyone has
Thread: philips dvp-642
only one I can answer is about the memorex media. Memorex dvd-r 4x discs work fine on my player. Memorex uses different manufactures though. The ones I got were prodisc s03's. They work in the xbox too, but my daewoo 5800 won't read 'em
so i guess i'm back to riteks or maxells next time around.
whats the media code on your memorex discs.. if its CMC its not working just because they're crappy discs. heh. I think i'm going to avoid memorex next time, cause you never know what you're gonna get with them.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
