VideoHelp.com Forum
  1. If I were to encode something to DVD or SVCD using Interlace encode mode, and if the source is interlaced, how to determine whether I should set Top Field First A or Bottom Field First B (source video setting in tmpgenc).
    I had recently encountered a problem with this where I had to encode two separate files in a different way and then they would play properly (even joined) in home DVD player.
    Thanks for any input.
    d
  2. Member daamon's Avatar
    Hi dinkob,
    If your source is from a miniDV cam, it's usually lower field (B field) first.
    Also, TMPGEnc should be able to figure out the field order of an interlaced source and so it'll default to the correct one.
    As for a tool to use to identify the field order - I'm not aware of one, but that doesn't mean there's not one out there...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member mike909's Avatar
    I too, would like to know if there is a tool to identify the field order of files. I know DV footage is usually lower, but I am often working with all different kinds of footage and would like an easy way to see what field order I should use. When I export as mpeg2 for dvd production, I often have mixed footage and the final result looks messed up for some of the footage and find for others. My solution would be to convert all files to the same field order, but I can't figure out what that should be.
  4. Member dphirschler's Avatar
    Here's my method.
    Load the video into Virtual Dub. Add the deinterlace filter and set it to unfold fields side-by-side. Step through the video and watch the motion. A scene change is easiest if you can find one. If you see the left side change first then it is TFF, otherwise it is BFF.
    Darryl
  5. Member mike909's Avatar
    yea, another 'long way' of determining it, is to load it into tmpgenc (thought this doesn't allways work correctly); also, tmpgenc express identifies a different field order (for me anyways) than pre-express versions do (specifically 2.5). I'm surprised that with all the problems that end up being the result of wrong field order selection, there isn't a tool for identification.
  1. Field Order
    By Tafflad in forum Authoring (DVD)
    Last Post: 30th Jan 2010, 00:38
  2. Field Order Problem?
    By GordRocks in forum Authoring (DVD)
    Last Post: 4th Mar 2008, 09:19
  3. Determining field order
    By dadrab in forum Video Conversion
    Last Post: 4th Oct 2007, 15:09
  4. Field order?
    By miamicanes in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Sep 2007, 16:14
  5. Need to change field order
    By Loko in forum Newbie / General discussions
    Last Post: 20th May 2007, 20:32
