VideoHelp.com Forum
  1. I have been burning DVD's for a while and have tried a few formats of DVD media. I have used Datasafe and Bulkpac.
    Just a simple question
    I have a cheap DVD player and want to backup with cheap media. However, you get what you pay for! Can someone recommend the best media around without spending too much money! I simply want to 'backup' my DVD's, but have been having playback trouble. ie pixel breaking up etc......
    I could spend weeks looking through this forum.
    Cheers!
  2. Member chicola's Avatar
    Search for the media that burn well in your recorder (http://www.videohelp.com/dvdwriters) and crosscheck them with the media that play well in your DVD player (http://www.videohelp.com/dvdplayers).
    Then you should have an answer.
    "Adopt, adapt and improve!"
  3. Originally Posted by PCBasher
    Cheers!
    And you will, I'm sure
    Having a cheap player probably means using good media is even more important than with a top-quality player. Yes, you get what you pay for.
    Cheaper players might not have the quality control on things like laser power, focus, spindle wow and flutter, heat removal, etc. This means you are probably better off removing the one big variable you do have control over - media quality.
    All media is pretty reasonable nowadays. You can get top-grade 8X Taiyo Yuden media for 65 cents each (Rima). True you can get the cheapo stuff for 20 or 30 cents, but is it really worth it to save a few bucks on a spindle if you're going to be getting freezing, stuttering, data read error blockiness, etc? Assuming you get a good burn, which isn't a foregone conclusion with the ultra-cheap media like Princo and CMC.
  4. I had a few brands that I had to burn at lower speed to get perfect burns (Princo, Sky, etc..).
    Apart from that they were OK.
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  5. Originally Posted by Capmaster
    I bought a cheap player last year and it turned out to be less picky than my expensive Philips!
    Regarding the cheap media compatibility question, u should get some media from several brands to see which one works on ur player.
    Give a person a fish and you feed them for a day; teach that person to use the Internet and they won't bother you for weeks
    Have you noticed that a slight tax increase costs you two hundred dollars and a substantial tax cut saves you thirty cents?
  6. Member Sabro's Avatar
    Exactly what I did, got a spindle of dvds that I know worked for me and kinda traded them around for other blanks with friends / family. No major loss and I was kinda able to judge what worked, what worked better or worse, didnt work at all without having a spindle or cake of duds.
    Sabro
    www.sabronet.com - It's all you need...to know
  1. Looking for a cheap and good standalone DVD player
    By Kweldood in forum DVD & Blu-ray Players
    Last Post: 28th May 2009, 07:54
  2. HDMI cables - cheap/expensive - does it matter?
    By snadge in forum DVB / HDTV
    Last Post: 1st Feb 2009, 20:32
  3. Expensive or cheap iLink/Firewire cable for video transfer?
    By chin569 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 2nd Jun 2008, 11:37
  4. Difference Between Expensive & Cheap Set Top Boxes?
    By markannab in forum DVB / HDTV
    Last Post: 3rd Jul 2007, 01:18
  5. A good cheap DVD/MP3 player
    By NES_Master in forum DVD & Blu-ray Players
    Last Post: 18th Jun 2007, 02:01
