I was wondering if it is possible to do a conversion from component video (from my progressive scan dvd player) to 1080i/720p (dvi input on my hdtv). Basically my dvd playback is good but not great. Since my hdtv set is 65" 480p leaves a bit to be desired. I was looking around on the net and saw that alot of the higher end DVD players have DVI output built in. However, mine does not. So if it is possible to convert my component output to DVI to up the resolution to 1080i or even better, 720p, I would be interested in doing so. Thanks for any help in advance =)
Lates
Ron Jon
Results 1 to 1 of 1
Are there any devices that can capture 480p with component through USB or P
By Cyber Akuma in forum CapturingReplies: 7Last Post: 2nd Aug 2009, 02:29 -
DVP5990 reverts back to 480P on my Mits 1080i TV
By dagmando in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Feb 2009, 11:08 -
Need USB/Firewire 480p capture over component
By Try4ce in forum CapturingReplies: 2Last Post: 3rd Jan 2008, 15:50 -
Capture HD from your game consoles for around $300 (480p/720i/p/1080i/p)
By Mysteriouskk in forum CapturingReplies: 4Last Post: 22nd Oct 2007, 19:00 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / HDTVReplies: 27Last Post: 13th Jul 2007, 16:25
