I've been doing some VHS to DVD transfers, and often put 2-4 videos on one DVD (the videos range from 20-40 minutes each). I don't like making chapter menus. I prefer just a single menu for the entire DVD that has a list of the videos to choose from. I'm using TMPGEnc DVD Author. I select "Main Menu only" in the options, and have the action after each track (one video per track) is played set to "Return to Main Menu". When I play the discs in my standalone DVD player, while a video is playing, I have to press "Top Menu" on the remote to return to the menu. Pressing "Menu" does nothing. This seems a little "non standard". I've never seen a commercial DVD where pressing the "Menu" button does nothing. Sometimes the "Top Menu" button does nothing, but the regular "Menu" button always seems to have some action associated with it. I'm having blurry menu issues (as posted in another topic), and am thinking maybe this is due to the way these DVD's don't meet the DVD standards. Is there any way to make it so the regular "Menu" button also takes me back to the menu?
I read somewhere that IfoEdit might let me do this, but I've never used it. Is there an option in TMPGEnc DVD Author? If not, how do I use IfoEdit to do it?
Thanks,
Brent
I have that same problem too. But what's wrong with pressing the Title button? At least it works. I have found that when I author using the free application DVD Author GUI, you can return to the main menu using the Main Menu button. However, it does not have those visual menu editors like TDA. You must create your own background image for the menu and buttons. The buttons can have a maximum of 16 colors and must be in BMP format. You can go to their website to see some tutorials. It's pretty simple, but much more time-consuming than TDA.
I don't really have a problem with it, but sometimes I do VHS transfers for other people, and I don't want them to have a hard time figuring out how to return to the menu once a video starts playing.
Plus, like I said, I'm trying to figure out why standalone players distort the menu when they return to it (not when it first comes up... it looks fine at that point), and I suspect a non-compliance with the DVD standard format requirements could have something to do with it. I described this issue in detail here:
http://www.videohelp.com/forum/viewtopic.php?t=238583
check in the IFO for the VTS containing the menu with IFOEdit and see if it shows a Root Menu in the VTSM_PGCI_UT in the top window
It's empty. Is there anyway to specify a root menu? Can I somehow substitute the Title Menu for the Root Menu, so both go to the same menu?Originally Posted by MackemX
Nevermind, I figured out how to do it with PgcEdit and IfoEdit. This post explained it perfectly:
http://www.videohelp.com/forum/viewt...=959580#959580
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 07:13 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
DVDLab Pro VMG and Menu Button and Chapter Skip on Remote
By raouliii in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 13:08 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 22:06
