VideoHelp.com Forum
Closed Thread
Results 1 to 11 of 11
  1. Is it possible to convert a DTS DVD (without any other sound) to become a DVD that will play (with sound!) on a non DTS player / hifi?
    errr without by a DTS system / player!
  2. Member yoda313's Avatar
    Hello,
    Try besweet. Though you might need some kind of dts plug in. I don't convert it much. Besweet would be the place to start. Good luck.
    Kevin
  3. Член BJ_M's Avatar
  4. Thanks - I'll give it a go tonite
  5. Sorry I must be thick.
    I can see that this will convert the sound from DTS but how do I put those audio files back into the VOBs to make a DVD up again?
  6. Hi,
    Im having the same problem. My DVD movie has only DTS sound
    and I want to conver it to AC3.
    After converting to AC3, how do i put back the audio
    into the VOB files?
    All dvds are authored with ac3 2.0 as well as dts etc anyway so if the dvd only has dts it will also have a dolby soundtrack,like for example Jurrasic Park DTS version and it also has a dolby 2.0 soundtrack.
  8. This is a DVD version with only DTS audio. No other audio. It a DVD-R movie iso release by some group and they only included the DTS track
    but my dvd player dont have DTS hardware decoder.
  9. Член BJ_M's Avatar
    you will need to:
    1. buy the movie
  10. Originally Posted by BJ_M
    you will need to:
    1. buy the movie
    Exactly. Buy the friggen movie instead of being cheap and spending 2 weeks re-authoring the thing.
  11. I guess its too difficult to do then?
  1. How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
    By fits79 in forum Newbie / General discussions
    Last Post: 29th Jun 2011, 22:30
  2. How i can convert dts-es to dts-core from one mkv file?
    By fits79 in forum Video Conversion
    Last Post: 11th Jun 2011, 21:24
  3. Convert DTS-MA to DTS with XMedia Recode?
    By smackyourfupa in forum Blu-ray Ripping
    Last Post: 14th Apr 2011, 08:23
  4. Replies: 0
    Last Post: 12th Mar 2010, 12:10
  5. DTS encoded disk, output to DTS receiver using an HTPC
    By ChipMcC1 in forum Media Center PC / MediaCenters
    Last Post: 18th Nov 2007, 07:06
