http://accessories.gateway.com/Acces...ductid=2520516
edit: that's even better! (see next post!)
Results 1 to 10 of 10
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Thanks to Gil T Pleasure(@dvdplus.org)
Here's how you can get the AR-230 for $135.
Use coupon code SAVE10TVAC, which takes 10% off the purchase price, lowering it down to $135. Then apply free shipping code NOSHIPA to get free shipping.
These are excellent DVD players too, almost worth it just to get another player!
How good are Gateway about returns if necessary?
Quick question...A couple of the reviews I have read mention that the unit doesn't playback over the coax, only the composite or component leads. Any truth to that?
No, I'm from Iowa. I only work in outer space.
Almost no DVD recorder has a modulated coax out. They all have signal passthrough.Originally Posted by babybooAnswers to Common Video Questions:
The only standalone that I have is a VCR/DVD combo which has coax out that carries TV/VCR and DVD output. Since the tv that I am insterested in hooking the Gateway up to doesn't have inputs I guess that I would need to use an RF modulator...My next question would be does the composite out carry TV/DVD output? I will hazarad a guess that it does otherwise anyone using it would have to keep switching their TV inputs while using the recorder.
I don't follow what you're saying, but the output from composite or s-video is fine, carries the recorder signal out, and pass through of any signal into it.Originally Posted by babybooAnswers to Common Video Questions:
What I am trying to say is that the TV that I was intending to hook this up to is an older 20inch with no line inputs of any kind, just a 75 ohm coaxial input. I assume that I would need to hook an RF modulator up to the Composite in order to view the output of the Gateway. Since I have never used an RF modulator my next question is are there RCA inputs on a modulator for audio?
I get it now...Originally Posted by babyboo
... Yes. It modulates audio/video into a coax signal.Answers to Common Video Questions:
Change to Gateway/Liteon firmware
By knights89 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Dec 2009, 15:32 -
Repairing a Liteon LVW 5001
By Toxie in forum DVD & Blu-ray RecordersReplies: 15Last Post: 19th Nov 2008, 10:49 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 21:15 -
Liteon 5001 and HQ mode problems
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 30th Sep 2007, 23:49 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 07:50
