Hi..I'm a Chem Teacher and I was wondering how would I take a powerpoint presentation and put it onto DVD?
Thanks.
I'm assuming you don't mean as a data file burned on a DVD-ROM. I think you mean as a video or a slideshow. Slideshow would be my guess.Originally Posted by John Shumate
You need to get each slide exported as a .JPG or another graphic file format. Number your images.
Then use an editing or authoring program that supports slide shows, like Ulead DVD Movie Factory, MPEG VIdeo Wizard, or Nero Vision Express. Most allow you to add sound in the background. Pull each slide into the "slide show" you have created.
Author to your DVD folders, with VIDEO_TS containing all your files. Then use a burning app like Nero to burn it as a DVD Video.
I have Nero Vision Express...but would it be possible to use TMPGenc DVD Author?
Thanks.
Any body?
Personally, I would use either MyDVD or VCDEasy to make an automatic/manual slide show with each Power Point slide as one of my own slides on the DVD.
Hello.
I've never really like VCDEasy...it never seems to work..but..thanks for your advice.
Any other ideas?
John,
You've already been given 5 different softwares that can do it. I'd suggest you try one of them
If in doubt, Google it.
I think http://www.powerpoint-to-dvd.com/ would be worth a look....
"speed's just a question of money. How fast can you go?" - Mad Max, 1979
How to add a DVD video to a Powerpoint Presentation
By andy jackson in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 12:27 -
how can i convert a powerpoint presentation and put it on dvd
By shashgo in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 03:14 -
Question about cutting clips for a Powerpoint presentation
By tanealbhandari in forum Newbie / General discussionsReplies: 16Last Post: 10th Dec 2008, 10:38 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2008, 23:59 -
Which video format works best in a PowerPoint Presentation?
By foochuck in forum Video ConversionReplies: 1Last Post: 4th Oct 2007, 09:54
