When backing up a dvd which audio is better to use ac3 5.1 or dts 5.1? Thanks.
Thread: ac3 5.1 or dts 5.1
AC5.1 is better for one reason ever DVD play can read AC5.1 if you only have DST some DVD player can not read it. Please read this link
http://www.videohelp.com/dvd
dts is supposed to be better than ac3, theoretically as it is at a higher bitrate. however, the difference is minimal and on some dvds, you cant even tell the difference. it is best to keep the ac3 track as this is part of the dvd video spec. without an ac3 audio, the disc does not meet the dvd video spec.When backing up a dvd which audio is better to use ac3 5.1 or dts 5.1? Thanks
dts also tends to take up more memory than ac3 due to its higher bitrate. if quality of video is your concern, stick with ac3. also, it is wise to note that ac3 is more compatible than dts.
DTS to AC3 5.1
By daemon22 in forum AudioReplies: 78Last Post: 24th Sep 2011, 09:04 -
Ac3 is indicated instead of dts - please help
By Dr Forrester in forum AudioReplies: 4Last Post: 16th Feb 2010, 09:19 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
AC3 to DTS
By Tolis1989 in forum AudioReplies: 2Last Post: 15th Nov 2008, 12:12 -
DTS vs AC3
By Mrsash in forum Newbie / General discussionsReplies: 9Last Post: 29th Jul 2007, 10:16
Statistics
Newest guides
Latest tool updates
New media comments
