I have the following problem, I have a dvd box which contains 2 dvd's with on each dvd's two movies. with there own menu, the first menu is the one you choose the movie, and then you come into the movie menu's. I want to loose the first menu, but keep the original dvd menu's and burn them to 2 seperate dvdr's. I cant find a way to do it. I tried dvdshrink, dvd-lab pro, but i really can't find out how to do it. Can somebody help me ??
you would probably have to change the first play command to jump directly to the menu of the movie you want. You can do this for free with Ifoedit or PGCedit
it may work just by doing this as it depends on your player. Sometimes the parameter values may cause the DVD to loop as you have skipped the main selection menu
there are tools and methods to bypass the first menu (mostly language selection bypassing) correcting this so all is not lost. This 2COOL's guide http://forum.doom9.org/showthread.php?s=&threadid=67564
you could also use something like Titlesetblanker to blank either movie if they are in their own VTS
Create PS3 readable HD movies split over 2 DVD-9s?
By darrellr in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Jan 2012, 10:08 -
Split bd 50 into 2 25gb disks
By fremat in forum Blu-ray RippingReplies: 1Last Post: 23rd Oct 2009, 09:04 -
DVD split with DVDFab. Movies don't run smoothly, goes back to first scene
By whenloverageswild in forum DVD RippingReplies: 1Last Post: 15th Jul 2009, 13:16 -
dvd movies don't screen on monitor properly are split into 3 sections
By beachychick in forum Software PlayingReplies: 3Last Post: 29th Oct 2007, 19:03
Statistics
Newest guides
Latest tool updates
New media comments
