ok Lately ive been getting blockiness and even FREEZEING on all my DVDrs I burn near the very end of the disk. now I dont know whats causing this problem? Im using the same ritek g4s and i burned nearly 200 successful DVDs. The DVDs in question DO NOT have labels or even anything written on them with a marker.. thier totaly blank.
The only possible thing That I think could be the problem is I updated my firmware to DR4GSB9 (from B6 I think) a couple months ago. Now this could be the problem maybe seeing as i never had problems on the old hardware.
does any1 have any idea as to what my problem is and also is it possible for me to downgrade the firmware on my drive? it says not to on The lite-on site but ill do it if i can.
BTW i tried the discs on 4 DVD players and they all have the blockyness/freezing (some worse then others) so I know its not the player.
well I found out of flashfix which allows me to change the firmware so I can downgrade.. Anyway I downgraded to a couple versions down (what i used to use)
im burning a disc now. If there is errors at the end then ill be stumped.
I had a slug of G04s that were giving me read errors even around the 2 GB area. Get Nero's CDSpeed.exe, click Extra, Scandisk, and Surface Scan. You may be getting read errors. I checked some of the ones I burned earlier and they were fine .... so it was a series in the middle of the same batch. I've since switch to TY +R and the first burn was right to the 4.3 GB limit ... no errors. But it's too soon to see if the whole batch turns out as good. I'm thinking +Rs may be more reliable anyway, from what I've been reading.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
well I just burned a movie again with the older firmware and it seems to be working. Ill keep with it for maybe 10 more movies and see what it produces
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 16:25 -
Burned DVD ISO playback errors
By Silver_Ice in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 13:24 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 21:15 -
Lite-On 5045GDL+ and bug with DivX & XviD playback?
By NorseGuy in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Apr 2008, 10:51 -
DVD-R playback errors
By blas in forum MediaReplies: 5Last Post: 6th Dec 2007, 13:58
Statistics
Newest guides
Latest tool updates
New media comments
