I'm trying to convert a divx to a normal vcd (not svcd), and everything looks like its converting properly using TMPEG 2.01, but then when i check the mpg file afterwards
all the movie is there, but all the sound is put at the end of the film.
so it plays the movie without sound, then it plays all the audio without the movie
hehe, anyone know how to fix this?
thx
use virtualdub to open the divx file and save the audio as a .wav file. you may want to verify that the length of the audio is exactly the same as the length of the video. load up the video file in tmpgenc, except use the extracted .wav file as the source for audio. encode for a couple of mins. stop and verify that the aborted .mpg has both video and sound.
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
How to disable End of Conversion sound on ffmpegX
By BS0D in forum ffmpegX general discussionReplies: 2Last Post: 16th Nov 2008, 19:46 -
no sound on movie
By natty in forum Newbie / General discussionsReplies: 9Last Post: 30th Aug 2007, 05:45 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
Statistics
Newest guides
Latest tool updates
New media comments
