Can someone explain why with the JVC DR-M10 that if I am using DVD-RW that it needs to be formatted in VR mode for on-disc timer recording to work?
I've used TMPGEnc DVD Author to successfully pull in DVD-RW Video files but what do I do if it's VR?
Does it?
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Quote from the manual:
> On-Disc Timer Programing is not possible on a DVD-RW disc
> formatted in video mode. (pg. 101, “Format a DVD-RW disc”)
In order to extract the video files from DVD-VR disk, you need a software that can understand the format. The latest version of several softwares from Ulead (UVS8, DMF 3, .. etc) and cyberlink (producer gold) can do it.
DVD-VR disk is in UDF format, depending on your OS, you may also need to install the UDF reader program. Nero InCD 4.3.x.x works for me on W2K.
Hope this helps.
When I finalize DVD-RW disk recorded in VR mode and put it in my Windows XP PC I can see all files. I think this is because Windows XP comes with Roxio CD burning engine and can read disks in UDF format.
Windows 2000 supports up to UDF 1.5. Windows XP supports up to UDF 2.1.When I finalize DVD-RW disk recorded in VR mode and put it in my Windows XP PC I can see all files. I think this is because Windows XP comes with Roxio CD burning engine and can read disks in UDF format.
I believe DVD-VR disk is formatted in UDF 2.1 and that is why Windows <2000 requires additional driver.
problem recording with jvc dr-m10
By restauroman in forum RestorationReplies: 3Last Post: 28th Feb 2010, 11:47 -
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 554Last Post: 24th Feb 2010, 17:54 -
JVC DR-M10 help
By colt4523 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2008, 06:53 -
How do JVC combo VHS/DVD recorders compare to M10 or M100?
By DGinnetty in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Sep 2007, 12:14
