Here is the file structure of the VCD:
Directory of F:\
F:\CDDA
F:\CDI
F:\EXT
F:\KARAOKE
F:\MPEGAV
F:\SEGMENT
F:\VCD
F:\
Total 0 file(s); Size: 0 Byte(s)
F:\CDDA
F:\CDI
Total 0 file(s); Size: 266993 Byte(s)
F:\EXT
Total 0 file(s); Size: 82561 Byte(s)
F:\KARAOKE
F:\MPEGAV
Total 0 file(s); Size: 733290844 Byte(s)
F:\SEGMENT
F:\VCD
Total 0 file(s); Size: 70592 Byte(s)
Total 7 folder(s); 0 file(s)
Total files size: 717 MB; 716515 KB; 733710990 Bytes
Does this mean I cannot remove the stupid Karaoke material(lyrics across the bottom of the screen) from this VCD? Sorry....I skipped VCDing and went straight to DVDing. I'm not too familiar with VCD's.
Thanks in advance if you can help.
The directory entries you provided show that the lyrics are embedded in the video stream, and can't therefore be easily removed. You may be able to use Tmpgenc to clip the picture, and then re-centre it, and remove the lyrics that way.
Nothing if not difficult
I was afraid of that seeing the empty Karaoke folder.
Thank You
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
Karaoke DVD of China DVD Karaoke player
By d0ming in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Apr 2010, 07:17 -
how to convert LD karaoke to VCD karaoke ???
By sandmankeren in forum Authoring (VCD/SVCD)Replies: 1Last Post: 7th Aug 2008, 15:53 -
Ld karaoke to dvd karaoke
By volam in forum Video ConversionReplies: 0Last Post: 27th Mar 2008, 09:13 -
karaoke VCD to DVD
By biemew in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2008, 05:16
Statistics
Newest guides
Latest tool updates
New media comments
