I am trying to install this friggin thing and it keeps giving me an error "improper function" "D:\i386\asms". Fatal error.
Anyone know why this keeps happening? I tried to upgrade 2000, this happened and failed to allow me to use the 2000 install anymore, so I formatted and tried a clean install, same problem.
So I took a different install disc and tried it, same error. Something is up here me thinks. LOL
Results 1 to 14 of 14
A bird in the hand is worth a foot in the tush-Kelly Bundy
Scratched disc.
I do not have a problem with my xp pro systems.
Search is your friend... and I thought this to be the problem...Originally Posted by devinemi83
Maybe a "copy" of an XP disc??
http://www.ntcompatible.com/thread18415-1.html
or
http://www.annoyances.org/exec/forum/winxp/1037767453
I suggest you check your "original" disc...
makntraksIn the theater of the mind...
It's always good to know where the exits are...
Well, heres the thing, I had to burn them because Penn state has a deal with MS called MSDNAA and you download an ISO from them of software and burn it yourself.
And this happens on 2 different cds, burned from 2 diff images.A bird in the hand is worth a foot in the tush-Kelly Bundy
That is why I said scratched disc.
I find "2" different discs being scratched hard to believe.....Originally Posted by gitreel
Out of all the discs I have laying around, I must be lucky....
Thats whats driving me nuts, I can see 1 scratched disc, even though it was burned today, it CAN happen. So I pull out a second xp pro disc and it does it again, same error. I thought maybe just the upgrade had screwed the pooch so I formatted and did a clean install, and yet again it bounced it.
EDIT: I think I am just having a bad computer week. Now I cant see my avatar anymore LOL.A bird in the hand is worth a foot in the tush-Kelly Bundy
It is not hard to believe. If you do not take care of your discs or if the discs get heavy use, then it is very easy to be scratched.Originally Posted by makntraks
Baldrick switched servers recently so you have to re-up your avatar...Originally Posted by devinemi83
If you are copying a scratched disc, there is also a possibility of missing files.
I dont know. I downloaded the ISO from the site used for pennstate and MS to distro their software so I would HOPE that they know how to make an ISO. And I have never had trouble burning an ISO. And the other install cd I have is from an entirely different ISO file so they couldnt be from the same source. So I am totally at a loss at to the answers LOL I think my machine just plain old doesnt like XP.A bird in the hand is worth a foot in the tush-Kelly Bundy
What are you trying to install it on?
Me smells trouble.....Originally Posted by devinemi83
I finally got it in. The trouble was with it trying to install on a fat32 drive. I set it to install with an NTFS filesystem and it worked like a charm. Very weird.
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
Exporting Premiere Pro to After Effects - WRONG in/out points!
By Namie in forum EditingReplies: 5Last Post: 8th Feb 2010, 00:20 -
All was well ...then whats the hell wrong with the sound
By qwerty00000 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 26th Sep 2009, 05:39 -
DVDlab Pro subtitle color wrong after compile
By nbarzgar in forum SubtitleReplies: 1Last Post: 9th Jun 2009, 09:29 -
DVD Studio Pro 4.2.1 - what am I doing wrong?
By jabbo5150 in forum MacReplies: 7Last Post: 9th Jun 2009, 08:22
