VideoHelp.com Forum
  1. Member beammeup's Avatar
    Hi,
    Firstly I live in Australia ( PAL land ) and I'm trying to capture a NTSC VHS tape to my computer.
    This is NOT a conversion question, just how to capture, or infact can my setup actually perform this task?
    I went and bought a NTSC VCR. I bought a stepdown power transformer
    to make it work on our 240v power system.
    I am trying to capture using Canopus's lets edit plus package with the supplied capture card.
    I have the software settings on NTSC, but all I get is B&W video with massive amounts of vertical roll.
    I have also tried to capture using Vegas, but similar non results
    For the record, I capture about 40 hours per month without any problems
    but it's all PAL VHS or camcorder stuff.
    Any ideas as to why I can't get a clear colour capture?
    Cheers
  2. Have you configured your card for NTSC? I live in NTSC land and the B&W roll is tha affect I would get if I switched the card over to PAL.
  3. Member beammeup's Avatar
    Hi
    Are you saying that there's a switch or something (physically on the card itself inside the PC)
  4. No switch, You'll find it somewhere in the configuration for the card or your capture app. Probably right next to where you select the source. I know you said you set the software settings but your missing something somewhere.
    I just looked at the specs for your card and it supports NTSC so it will do it.
  1. Replies: 0
    Last Post: 19th Feb 2012, 15:52
  2. Trying to get a good digital capture of an old VHS tape
    By StrobeLightEpileptic in forum Restoration
    Last Post: 21st Nov 2009, 21:16
  3. Replies: 2
    Last Post: 31st May 2009, 12:56
  4. How to capture a full VHS tape?
    By burrowsfan in forum Newbie / General discussions
    Last Post: 5th Feb 2009, 17:54
  5. Replies: 5
    Last Post: 27th Sep 2008, 19:49
