I'm looking for a set top DVD recorder that I can use in the field. Since I will be carrying it from place to place, size and weight are major concerns.
I had high hopes for the little HP DVD recorder, since it is the size of an external computer recorder, but the problem with it is - even though it has a built in encoder, it still needs to be connected to a computer.
So I guess I'll have to settle for a full size recorder. Anybody know which ones are the smallest??
Thread: Smallest Set Top Recorder?
I don't have a bad attitude...
Life has a bad attitude!
Have you considered video camcorder? Pricey, though.
http://www.amazon.com/exec/obidos/tg...2&vi=tech-data
Thanks for replying. I need the ability to record for two hours though.
The JVC is nice and slim.
The Sanyo and Pioneer may be smaller.
Most recorders are the size of a full VCR deck.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
A simple Google search will yield a few DVD-Camcorders and some of them will record to DVD-R/RAM, a bit pricey though.
what resolution will a DVD recorder set-top capture.
By xbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 11th Jan 2012, 15:40 -
setting up dvd / tv / set top box??
By wundahoss in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th May 2009, 12:48 -
Saw AWESOME HD recorder. No copy protection. HD out. Set top. Real time.
By Evilmind in forum Newbie / General discussionsReplies: 7Last Post: 13th Aug 2008, 18:56 -
Recording digital tv via a set top box
By rapattack in forum DVB / HDTVReplies: 4Last Post: 16th May 2008, 09:28 -
Help, unable to rip DVD created from a set top DVD recorder.
By pwangdel in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2007, 18:47
