VideoHelp.com Forum
  1. I have an mpeg file with the following specs that I wish to convert to SVCD PAL
    352x240 frame size
    29.970 fps
    1149 average bitrate
    I have a few newbie questions that I hope you may be able to help me with.
    Can I use TMPGenc ( Ver 2.5 ) to do all the conversion for me or would it be best to do some pre-conversion with other software prior to encoding with TMPGenc ?
    I realise this is an NTSC frame rate and I have read that converting it to PAL will give me a jerky picture. My DVD players can play either PAL or NTSC so would it be best to keep it in the NTSC format ?
    Is it just the frame rate, bit size and frame size that stops an Mpeg movie file being able to play as an VCD/SVCD or have I over simplified matters ? There seems to be so many mpeg files out there, yet 99% still have to be converted for use as an SVCD. can anyone explain in newbie terms why that is ?
    Many thanks.
  2. Member yoda313's Avatar
    Hello,
    If you can play ntsc I would suggest keeping it ntsc. If you change it you can introduce synch problems. The best way would be to make a ntsc svcd (normal procedures) and use a rewritable disc. Then if its out of synch you may have to make it a pal format. Just do a forum search for "ntsc to pal" and you'll find plenty of references.
    Kevin
  3. Member mats.hogberg's Avatar
    352x240 frame size
    29.970 fps
    This seems very much like a NTSC VCD file, so if your player can play VCD, then the conversion to SVCD is pointless - just author & burn it as NTSC VCD instead. Only thing that will happen if you reencode to SVCD standard is a decrease in quality, and twice the # of CDs...
    /Mats
    matts right, that's a vcd, you won't gain anyhting by converting it to svcd
    member since 1843
  5. Cheers guys.
  1. Replies: 0
    Last Post: 27th Nov 2009, 04:40
  2. MPEG I II IV conversions
    By cerebro in forum ffmpegX general discussion
    Last Post: 14th Oct 2009, 15:49
  3. mpeg-ts and .ts conversions
    By nirbhayn in forum DVB / HDTV
    Last Post: 30th Aug 2009, 18:00
  4. general questions about color space conversions
    By jieve in forum Video Conversion
    Last Post: 9th Aug 2009, 16:56
  5. Some Questions about Conversions and File Formats...
    By dadada_999 in forum Video Conversion
    Last Post: 20th Nov 2007, 21:29
