VideoHelp.com Forum
  1. Member victoriabears's Avatar
    I have a concert on vhs that, probably due to its age, has jumps and skews on it, I am probably not using good descriptions, so if you follow the following link you'll see a very small clip showing my problem.
    http://www.evergreenhideaway.com/private/cliffsmallclip%20(02).mpg
    Would using a good TBC do any good, or a very accurate editing program to edit out the section, hoping it does not affact it too much.
    I do not know what is causing this, I have used many different vcr's to play it on, all the same, either its because its an old tape, although earlier sections of the same tape/different program are fine, or that the recording itself was hit by a gremlin at the time.
    Thanks as usual everyone
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    Even the best TBC in the world is not going to be able to get Cliff Richard off the tape - that's just the way it is.
    The glitches actually look more like physical tape damage to me, so even a TBC isn't going to do a lot for you. Have you inspected the tape surface at these points for creases ?
  3. Member victoriabears's Avatar
    i was hoping we would avoid the Cliff bashing!!!!!!!!!!
    I was fearful of your suggestions, but thanks anyway.
    Cliff rules!!!!!!!!!
  1. Replies: 0
    Last Post: 12th Apr 2011, 22:34
  2. Problem Using ProjectX: the sound's output is "corrupted"
    By devilcoelhodog in forum Newbie / General discussions
    Last Post: 12th Nov 2010, 16:22
  3. Quality problem "caused" during "deinterlacing" ?
    By Hombre_86 in forum DVD Ripping
    Last Post: 25th May 2010, 21:28
  4. corrupted m2ts file - "cannot detect stream type"
    By ac1j2 in forum Newbie / General discussions
    Last Post: 4th Mar 2010, 07:51
  5. "bits/pixel" as indicator of quality?
    By Information in forum Video Conversion
    Last Post: 13th Oct 2009, 17:50
