I know why some of you are having problems with your encodes desynching. If you are playing movies that are around 700mb in AVI format and the movies are on 700mb media, you are probably going to get desynch issues due to the burn. Jamming all 700mb of the movie onto 1 disc leaves a lot of room for burn errors, especially towards the end of the burn since the burn speed is always faster.
There are factors to consider here.
Burning slower can help, but my suggestion for those of you having problems is this:
1. make sure you burn SLOW because the FASTER-IS-BETTER theory is just a myth.
2. use DVDR's and burn SLOW. 4x is more than enough and you can fit quite a few movies on 4.7gb discs![]()
I still haven't had a disc with desynch problems whether I used 700mb cdrs or 4.7gb dvdrs. Good luck!
Results 1 to 1 of 1
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 16:26 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Jun 2007, 23:16 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
