I can't open a file in virtualdub. It says "error decompressing frame 0" and it says that for every frame. I know the file is ok because it plays in VideoLan player. I've tried using avisynth but it says the same thing.
Thread: can't open video in virtualdub
sounds like you are missing a codec. What does gspot tell you about the file.
Gspot says:
Codec: Xvid
Bitrate: 1600
FPS: 25
audio
codec: ac3 stereo
bitrate 192 CBR
I've tried to reinstall the codec and it still does not work
Could it be I have to many installed? gspot says I have 61 video codecs
Its just that your Xvid is a directshow (decoder only) i think, and virtualdub cant use directshow codecs. Get the newest build from koepi, you'll find it in www.videohelp.com/tools.
In vdub when you select video and then compression does it show xvid as one of your codecs. Like thor300 says ffdshow will decode xvid for playing but virtualdub cant use it. Download and install either koepis or nics xvid build.
Open h.264 in VirtualDub
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 6th Nov 2011, 20:21 -
How to open WMVA with VirtualDub?
By Zeokat in forum Newbie / General discussionsReplies: 5Last Post: 24th Oct 2011, 03:47 -
Cannot open H264 video using VirtualDub
By kinlunyu in forum Video ConversionReplies: 12Last Post: 21st Aug 2011, 14:28 -
can't open flv in VirtualDub
By shun in forum Video ConversionReplies: 3Last Post: 26th Jul 2010, 18:10 -
Virtualdub can not open xvid
By quxote in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2009, 00:11
