Hi,
Does anyone do this? I'm sure this has been posted before but can't find it.I Always see it customers computers set to 30 minutes and just wonder, why? Does it "hurt" the drive to turn it on and off? What does it really do? Just stop it from spinning? IF that's the case wouldn't it just spin/stop/spin/stop all the time?
Thread: Turn off HD in power options
Whatever it does, I assume it makes the HD use less power, which is the point. If you aren't using the computer why run up your electricity bill with it? Or if you are on a notebook, why waste your battery?
I would imagine that "waking" up your hard drives is no more damaging then booting up.
Takes a few seconds to spool up, that's why they don't power off all the time. It's said that drives built for constant running don't like being shut off at all, so maybe not such a good idea for SCSI drives. I wonder if there's a way to keep the SCSI drives in my PC running and let the IDE drives power down.
Is your SCSI controller onboard or a card?Originally Posted by rallynavvieNothing can stop me now, 'cause I don't care anymore.
Both are host adapters. Surprisingly few workstation boards have onboard SCSI these days. The option would be in XPs power settings anyway. Unless there's an advanced version of that I'm missing somewhere that allows you to set the drives individually.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Two wdtv gen 1 questions - usb power options and avchd playback
By yoda313 in forum Media Center PC / MediaCentersReplies: 8Last Post: 5th Jan 2011, 18:18 -
Is it Possible to Turn Off Internal HD to Save Power?
By imdaman in forum ComputerReplies: 7Last Post: 18th Sep 2010, 11:27 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
Turn lcd monitor into a tv Any other options
By canadateck in forum DVB / HDTVReplies: 4Last Post: 6th Nov 2009, 19:28
