Results 1 to 14 of 14
  1. i just removed a 20 GB hard drive from my old pc, and a great yamaha CDRW drive, that i love
    i wanna get encloseres for these to use with my imac g4
    could anyone suggest any good, and cheap ones?
    i realy only need one interface. Thanks!
    -eric
  2. Member WiseWeasel's Avatar
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    Otherworld Computing: www.macsales.com
    depending on where you live, Fry's electronics has good periodic sales.
    I got a ADS Dual Link drive kit ( usb2 and firewire400) for 39 $ after a 30 $ rebate. they also have Hitachi 250 gb drives over and over for 99$
    rotut
    If you have $105 and you want just one case
    http://shop.ily.com/P_567.htm
    If you have $50 and you dont mind 2 cases
    http://www.pcmicrostore.com//PartDet...x?q=p:10501012
    DoH!
    that last link was usb 2 only here is firewire for $37
    http://www.coolerexpress.com/
  6. i haven't bought from them, but they have a great selection:
    http://www.cooldrives.com/firen.html
    For Firewire 400 be sure to get one with the OXFORD chipset, most will use that..but make sure.
    Now, I want a Firewire 800 dual or quad enclosure, but don't know which chipset is best??? Oxford 912 or 922 (912 i think is better) OR the Initio chipset? I would go with the Oxford 912 but few cases use it. Anyone?
    maybe this should be a thread all it's own...
  7. Member WiseWeasel's Avatar
    The Oxford IDE/FireWire bridge chips are typically the best, with the highest performance. The Oxford 911 chip is for FireWire 400 Mbit, and the 922 is for FireWire 800 Mbit. Never heard of the 912, but I'd go with the 922, personally, as it is a newer generation than the 91x chips.
  8. I couldn't find much on the 912, but this is where I saw it *may* be better than the 922:
    http://barefeats.com/fire45.html
    "Both the Big Disk Extreme and the d2 Extreme use the Oxford 912 bridge chip,
    which is reportedly superior to the Oxford 922 chip used by most FireWire ... "
  9. Member Webster's Avatar
    For $53 and changes, you can get one of this dual firewire case while supply last.
    http://www.compgeeks.com/details.asp...02F-01&cat=CAS
    edited: my bad.... it is only for 3.5'' drive, the CDRW probably will not fit...
  10. that thing from compgeeks is junk, and they're support is the WORST- ALL SALES FINAL!! it is not ATA-6 so it really doesn't work with drives over 120GB, if you can get two working in it all! depends on the brand and size... STUPID! avoid this thing unless you want hassles, or just plan on using it for ONE drive, then it MIGHT work. This thing has only caused me headaches, although the build quality seems solid.
  11. Member Webster's Avatar
    Strange, I'd got mine to work with a 160G Maxtor and a ZIP drive.......
    Who made your drive?
  12. I was able to get a Maxtor 160 OR a WD 200 to work, but only one at a time, nor did an additional Maxtor 120 or IBM 30GB work as a second drive. If I remember correctly the it may have seen the first 128GB of the WD... not positive. If you EVER have to deal with their tech support or customer service, you will never buy from them again. They are EVIL!
  13. it looks like on the back of that dual 53 dollar one, that there is a spot underneath the firewire ports for a PCI card, if i have an extra usb 2.0 card, would that fit it it?
    thanks for eveyones responses by the way!
    -eric
  1. hard drives
    By Willy5157 in forum Computer
    Last Post: 23rd Oct 2009, 05:16
  2. Hard Drives
    By jason in forum Newbie / General discussions
    Last Post: 14th Apr 2008, 12:50
  3. What's cheaper HD/BR drives or hard drives for backups?
    By Leander in forum DVD & Blu-ray Writers
    Last Post: 20th Apr 2007, 04:15
Slysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
