Dear Friends,
I want to author a VCD with Menus in VCDEasy.
1-Company Logo.
2-Main Menu.(Button-1-Play Movie.Botton-2-Select Songs)
3-Song Menu.(List of songs may be 3 or 4)
4-End of dics 1 insert disc 2 (TGA or BMP or MPEG still picture)
I want to Author in such way that if i select Button NO-1 whch is (Play movie)
the movie should start from start to end and after movie the end disc TGA should appear.
When i select Button No-2 which is (Select Songs)All songs shouls play one after other and after completing it should come to the song menu insted of main menu.
I mean like Play List.I used to do this in VideoPack-4.Is it possible to Author the same way in VCDEasy.I am using VCDEasy becausei want to over burn the cd till 88Mins.
Please help and oblige.
Thanks.
Zerohash.
Thread: Interactive VCD in VCDEasy
First off, if you have a spare copy of winoncd then you can still use vid pack 4 and overburn. Save the raw track in vid pack, import into winoncd and save to a project file. Open it in CDMage and convert to bin and cue. Then you can burn in just about anything.
As for VCDEasy, yes it can do all that and more. If you are using still menus then you don't even have to use the # keys to select items. You can simulate hotspot buttons. You just create multiple items showing the "button highlight" over each option. Then you link between them with the next and previous keys and use enter to select that item. Basically, it functions exactly like a DVD except that you use the next and prev track keys to navigate instead of the arrow keys. This of course can all be done in vid pack 4 as well.
To see what I mean check out this section of my guide.
http://users3.ev1.net/~CavemanLawyer/Paint.htm
And try downloading the sample disk image to see how it functions on your hardware player. Get it from the main page.
As for how you create all the functionality you want? I don't know what else to tell you except to learn what the functions of VCDEasy are. You want item A to go to item B when you hit button C? Then you simply go to item A and find the C option, and set it to B.
For a description of how VCDEasy works, check out this page.
http://users3.ev1.net/~CavemanLawyer/Vcdeasy.htm
Dear Adam,
Thanks for your quick reply.
I created a .raw using Videopack 4.0.I have WinOnCd 6.But I was not able to import the Videopack .raw files.How does one do it?
I then created a Project using WinOnCd 6 made a Disc Image but when I open it in CDmage it gives me an error "Invalid format of File".
Moreover I got jerks in video and audio when I burnt a VCD using Easyvcd.I have Plextor PX 5224TA Writer and used 4X writing speed using generic-mmc driver.I then created an image file using Easyvcd and used Nero to burn the VCD using 4X speed.The Jerks were still there.But when I use the same MPG file to burn a VCD using Videopack 4.0 and Winoncd 6.0 at 4X I got a clean VCD without any jerks.
Where could I have gone wrong???
Looking forward to your reply,
zerohash
Interactive DVD menu
By aloram in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2010, 01:10 -
Interactive Games
By natty in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2009, 09:58 -
An Interactive Movie
By Kadratis in forum Authoring (DVD)Replies: 6Last Post: 28th Mar 2008, 00:41 -
Interactive DVD`S
By natty in forum Newbie / General discussionsReplies: 18Last Post: 5th Feb 2008, 02:58 -
interactive video engine
By nojee in forum ProgrammingReplies: 1Last Post: 29th Jun 2007, 06:34
Statistics
Newest guides
Latest tool updates
New media comments
