Hello.
Is there a FILTER to avoid those"squares","blocks" while playing divx???
Specially in dark scenes...
How are they called????
if I knew how they are popular called, I could startup a research about it.
Thanxs
Ok than you so much!!!
Now at least I know the name o f my enemy "Macroblocks".
I understood what you posted, but I am looking for a filter not to encode the video.
It is a filter to avoid this macroblocks during divx playback, ok???
any suggestions???
Thanxs
You could try and lower the color a little (darken it somewhat) while playing
the video. I think that Zoomplayer soppose to be pretty good at this, last
I played with it.
-vhelp
Doesn't the Divx (and Xvid) codec have a "Film Effect" option on the decoding options... As I understand it, this adds a little grain to the playback picture, this could do something to hide the macrosblocks.
Also, the latest Xvid codec has a "Deblocking" option in the decoding options, can you change the fourCC code in a Divx file, so its played back with the Xvid codec? ("Nic's FourCC changer" is included with the codec).
MSU Video has a free v-dub filter just for this ...
http://www.compression.ru/video/debl.../index_en.html
works"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
NAME="mplayerc.exe" FILTER="GRABMI_FILTER_PRIVACY"
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2008, 15:40 -
How to actually close "open GOPs" abd avoid warning with DVD Lab
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 23:42
