VideoHelp.com Forum
  1. Does it matter whether you use a 40 or 80 pin ide cable ?
    My burner is a LG4120B.
    TIA
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Not really with a slower device like a DVD, but I would still use a 80 conductor cable (The pin count is the same on both) because it has extra ground leads and this may lessen the chance of electrical interference.
    If the burner operates in PIO Mode 4 or ATA/33, then a 40 pin cable is appropriate. If it operates at ATA/66 or higher then an 80 pin is required. Depending on your computer it may or may not inform you to use a 80 pin cable if a 40 pin is installed in such drives. If you have an 80 pin available use it.
    Best of Luck,
    -Evan-
  4. Member ViRaL1's Avatar
    Are there any optical drives that operate above ATA-33? Even 16x is only about 21MB.
    Nothing can stop me now, 'cause I don't care anymore.
    Yeah, I've encountered a few with ATA/66 electronics... not that they need them (as you pointed out). Have yet to see an ATA/100 optical drive, but it would be a good promotional spec.
    -Evan-
  1. LifeView Video III Cable, Looking for Pin Outs or Substitute.
    By Computer Nerd Kev in forum Capturing
    Last Post: 27th Nov 2011, 05:44
  2. Looking to get a new IDE burner
    By moonhoney2 in forum DVD & Blu-ray Writers
    Last Post: 29th Oct 2009, 10:23
  3. About IDE to USB adapter cable
    By AusTaylor in forum Computer
    Last Post: 4th Feb 2008, 00:18
  4. ide dvd burner and sata harddrive - how do i configure?
    By mshuang in forum DVD & Blu-ray Writers
    Last Post: 12th Dec 2007, 00:46
  5. IDE DVD Burner VS SATA DVD Burner
    By mn072065 in forum DVD & Blu-ray Writers
    Last Post: 13th Nov 2007, 20:15
