I am using Panther 10.3.4 with a Pioneer DVR Drive
How do I configure MMB or Firestarter to allow overburning of a 710 MB Xvid onto a 702.x MB CD
Do I burn it as a Data file? - do I have to make it into another format before burning?
What is the maximium data that can be placed on a CD of this capacity
tia
Thread: Overburn Xvid onto 702.x CD?
This should work: create a non-write-protected disk image in disk utility, mount it, copy the xvid into it, and unmount. You now have a dmg that is something over 710MB. Then go to MacOSXHints and do a search for 'converting dmg to iso', there was a hint there a while back for doing that. You should be able to burn the iso in Firestarter (check 'overburn if needed').
Tim Houghton
My digital life
Thx for the suggestion
- seems MMBs enable to do it directly to iso/img using CDRecord
Thought a lot of others may have already attempted overburning
Is there a substantial risk of damaging the drive by doing it!?
Never felt the need to try it, but I seriously doubt it could cause problems ... (how could it possibly do any damage?)Originally Posted by PretzelTim Houghton
My digital life
I use FireStarter FX to overburn. Go to "Burn Data" at the top of Firestarter's window. Put your file into a folder. Drag the folder into the "Drop Zone" Firestarter's window. Click "Burn" in the lower right corner of the Firestarter window. I've experimented with Firestarter's overburning capabilities, and I've found that I can overburn up to 730MB. Good luck.
questions on Daweoo 702 DVD.. plz help...
By aKrAbI in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Dec 2003, 01:39 -
Daewoo 702 DVD
By aKrAbI in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Dec 2003, 05:49 -
How do I burn a 702 MB .avi file on a reg 700 MB cd?
By AndyE12 in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2003, 23:30 -
AVI to AVI conversion - Want to make 702 MB -> 700MB
By diabeticus in forum Video ConversionReplies: 5Last Post: 1st Jul 2002, 05:19 -
Philips DVD 702 VCD playback problem
By VCDnewbie2001 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Aug 2001, 09:12
Newest guides
Latest tool updates
New media comments
Recent DVD Hacks
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
