I paid $36 for a 6ft. Is this reasonable? It cost more than the fire wire card.
Results 1 to 18 of 18
Thread: dv to firewire cable
GuestGuest
I paid like $6.99 for mine from www.newegg.com.
Online prices were a lot cheaper than the local stores, I mean a lot cheaper!!!!
You definitely screwed yourself. I got a card with cable for $12
GuestGuestWhere?Originally Posted by FOO
Some of the really good, thick cables from Belkin and others run uplwards of $30.00. I recevied a cheapy with my fw card... very thin cable..... threw into drawer..
You probably bought quality
GuestGuestIt was a belkin.Is quality improtant for video transfer?i.e what happens with shitty cords/cards?Originally Posted by DVD_Ripper
Not sure... but you may have interference (other power cords, transformers, etc) and a good cable may resolve bad burns (ext burner) and even fuzzy video. Are you going DV --> PC now... try Mainconcept Media Encoder.Originally Posted by Dr.Gee
Knock on wood, my cheap cable works great.
From Mini DV cam to computer in DV format.
GuestGuestDoes 4pin=DV?
Mine is a 4pin to 6pin.
4pin on camcorder, 6pin on computer firewire card.
GuestGuestI have a sony cam with a nearly square "DV" out. I've seen both "DV to Firewire" and "4pin to 6 pin firewire" labled cables.Are these the same?
I'm pretty sure they are. I bought a FireWire interface and it came with a 4-6 cable and Ulead software for $20 at Fry's... And the cable fits my Sony's iLink port perfectly.Originally Posted by Dr.Gee
Yes I agree, I have a Sony Cam also.
The smaller 4pin for the camcorder, the larger 6 pin for the firewire card.
GuestGuestAwesome .Compusa has one for $6.28.
Any chance you got it at Best Buy? Last time I checked, their cables were ridiculously priced. I think they lure people in with the promise of low-priced components and then make their killing on the accessories like cables.
either way you got screwed. i got my cables from this place. they sell good cables and their 33' cable is $34.
http://www.1394store.com/eshop/dept.asp?dept%5Fid=6
Most camcorders and laptops are 4 pin, most desktops are 6 pins.Originally Posted by Dr.Gee
For cables, there are 4 to 4, and 4 to 6 (commonly).
6 pin Firewire includes power and ground. I use one for my external Firewire laptop drive. (6pin to 6pin)
What firewire cable do I need?
By Jedi5 in forum MacReplies: 3Last Post: 7th Sep 2011, 16:17 -
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 1st Aug 2010, 12:28 -
firewire to usb 2 cable
By pavilion1250 in forum Video StreamingReplies: 2Last Post: 15th Apr 2009, 21:01 -
firewire cable required
By rizvi in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Mar 2009, 06:14 -
Ipod firewire cable?
By budz in forum Portable VideoReplies: 0Last Post: 27th Nov 2007, 20:22
