Hi
What’s the best bitrate mode to choose, when capturing from a TV-Antenna signal into mpeg2 codec?
Variable Bitrate?
Or…
Constant Bitrate?
I don’t want to lose any frames or witness jerkiness in the final video.
Also I’m thinking about capturing in this resolution: 720x576 PAL
I have a Leadtek WinFast DV2000 Video Capture card.
Thanks in advance.
Try both and see. If vbr gives no dropped frames I would go with that as it should give better picture quality for the same bitrate.
-Suntan
Assuming you mean using your 2.4 GHz CPU machine, I would say that there is little chance of dropped frames because of CPU demand. Any problem would likely be caused by other factors, like bus speed, card limitations, etc.
Generally VBR is much more efficient than CBR in that it uses some intelligence during the capture - ramping up bitrate for action scenes, and dropping it for static dialog scenes, for example. I don't see any good reason for anyone to use CBR unless they have had problems specific to the VBR capture mode. That's just my opinion, but I think most of us here use VBR for quality reasons.
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 07:49 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 04:35 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 07:58 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 17th Oct 2007, 23:56
Statistics
Newest guides
Latest tool updates
New media comments
