Hello,
I am fooling around with the delogo plug in forvirtualdub-mpeg2 to remove tv logos on videos. I know you lose some quality when converting .mpg to divx (dvd mpg from a wintv pvr250 capture card). My quesiton is can I use the bitrate that was recorded for divx to preserve quality?
Say I captured something at about 3000 kbps (dvd long play capture mode), can I use that as my divx compression and not lose much quality?
The other question is, would I be better off at using the High Definition option in Divx and cranking up the bitrate to 8000 or so?
I'd like to know what the IDEAL compression bitrate would be to keep the quality close to the original. Thanks in advance![]()
Kevin
P.S. I know you can't get EXACT quality but I would like an idea of how high to set the divx bitrate to preserve quality (as best you can).
EDIT --- My goal is to go from .mpg to divx for the logo removal and then divx back to mpg so I can put it on dvd, thanks.
The answer to this question is Yes & No.Originally Posted by yoda313
The bitrate (and playing time) determines the final file size. So in this respect, divx and mpeg are the same. An mpeg file withh 3000Kbps and a divx file with 3000Kbps (of the same length) would be the same size.
But the bitrate needed to achieve a certain quality level (however it is measured?) is lower for divx than mpeg 1 or 2.
For your situation, keep the resolution of your divx the same as the mpeg. Keeping the bitrate high (same as the source mpeg, high in divx terms) would help to minimise quality loss.
Better still, if you have the disk space, convert it to mjpeg or even huffy for the vdub filter work.
Under no circumstances should you change the resolution at any stage unless you really have to. (such as to make it DVD compliant).
Hello,
Thanks for the responsebugster -For your situation, keep the resolution of your divx the same as the mpeg. Keeping the bitrate high (same as the source mpeg, high in divx terms) would help to minimise quality loss
. I was wondering if that was the best route. I didn't want to do the overkill approach. I have a 40gb harddrive so I don't think I want to go too large on the filter stage.
I'll give it a go and hopefully matching the bitrate will preserve as much of the original as I can. Have a nice day.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 10:17 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 23:20 -
ASF to Divx, similar bitrates?
By bigMach™ in forum Video ConversionReplies: 3Last Post: 27th Aug 2008, 14:32 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 13:54 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 21:50
Statistics
Newest guides
Latest tool updates
New media comments
