I have a DIVX AVI which has perfect sound/video sync for about an hour, and then, toward the end, there is a brief pop or snap in the audio, after which the sound/video are a little out of sync. If I can somehow cut out that pop from the audio track, or insert blank space in the soundtrack. I believe the sync will be fine. Right now I'm not sure if the audio is ahead of the video or behind it. The sync problem does not get worse gradually. It is constant after that one point.
I'm currently using TMPGEnc to export the audio and video as elementary streams. I will soon have an .m2v, .mpa, and .wav files. Any strategies on editing the sound and recombining would be appreciated!
Thanks!
Results 1 to 1 of 1
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
Audio goes progressively out of sync. Calculate the "rate of change"?
By rayden54 in forum AudioReplies: 1Last Post: 26th Sep 2010, 07:48 -
"fixed" AVI has audio sync and video blocking problems
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 05:00 -
"Insufficient audio data or severe sync problem"
By carsskee in forum ffmpegX bugs and suggestionsReplies: 2Last Post: 2nd Aug 2009, 17:31 -
Attempting to demux VOB gives pop-up "file error" window eight ti
By taa in forum ffmpegX bugs and suggestionsReplies: 6Last Post: 31st Aug 2008, 02:02
