I've got a Ricoh 2.4x DVD+ burner. I've been using Bulkpaq 2.4x discs until now but supplies seem to have dried up. Can I use higher speed discs to write with? For example should a 4x write at 2.4x? The reason I ask is because initially I used Bulkpaq 4x but ended up with a lot of coasters. When I switched to 2.4x, everything was fine. Obviously I don't want to waste any discs this time. Should I try another brand?
Thanks.
My Sony likes Verbatim Datalife 1-4x at 2x.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
I have an HP 200i, a RICOH clone. 600+ error-free burns on RITEK 2.4 DVD+R's from www.rima.com . $56. for a hundred plus shipping.
I have Maxell DVD+R disc that support 1-4x burning. It has the warning on the back indicate that you need to upgrade the hardware(i guess your burner) if your burner is 2.4x if not it will result in writing error. Then it give you this address to upgrade www.dvdrwservices.com
Thanks. Ok I think I need to try and get some 1-4x speed discs.I tried upgrading the firmware but it wouldn't load so I'll just have to chance it.
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
Can you burn at higher than the media advertised speed?
By tamgelikah in forum MediaReplies: 13Last Post: 19th Sep 2008, 04:57 -
Speed on External DVD Writer
By mn072065 in forum DVD & Blu-ray WritersReplies: 6Last Post: 30th Sep 2007, 16:45 -
Anybody know how to change the speed of DVD Writer?
By mommyc in forum DVD & Blu-ray WritersReplies: 30Last Post: 25th Sep 2007, 15:58 -
Writer forces speed up to 8x
By gmacman in forum DVD & Blu-ray WritersReplies: 3Last Post: 16th Aug 2007, 14:56
