Hello!
I have AVI movie, and want to add Permanent Subtitles with TMPGEnc program.
The problem shows up, when I want to compress it to DiVX(.avi)
A window shows up, DiVX Pro Ad Support Missing, which telling me, that I'm using the Ad-Supported version of DiVX Pro software. The GAIN Software must be instaled on this computer in order to use DiVX...
and a little bit lower it says:
It Appears that the GAIN software is not installed on this computer. Please re-install the DiVX Pro software and try again.
I must tell, that I allready DL DiVX 511Pro GAIN Bundle, but nothing new shows up. The same old problem.
I want to keep the quality of the .avi video, and dont want to change it to MPG, because I allready know how to do that, and if I want to put movie on 1 CD, either Quality is LOW or I cant put it on 1 CD, because the file is to big.
I will be very glad if someone could help me with this riddle.
Thank you!
Results 1 to 1 of 1
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 04:11 -
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 20:16 -
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 238Last Post: 23rd Aug 2011, 20:56 -
How do I add or edit permanent subtitles
By VidHunter in forum MacReplies: 19Last Post: 29th Nov 2007, 14:55 -
Add permanent subtitles to an AVI file using a MAC?
By blueblitz in forum MacReplies: 1Last Post: 15th Oct 2007, 05:10
