I couldn't find anything in the DVD media section, so I figured I'd start a topic here.
If you have any experience with good/bad media for the JVC, please post here. Based on my experience, I don't recommend using Verbatim Datalife DVD-R media from Sam's Club (made in Taiwan by Mitsubishi). See my other post on the subject:
http://www.videohelp.com/forum/viewtopic.php?t=231874
I can recommend the Maxell DVD-R media at Walmart.
Thanks.
It's almost impossible to recommend a certain brand of media since many of them are using numerous manufacturers. For instance, I use mostly Fuji media and the 50-packs are made in Taiwan by Ritek wheras the smaller packs are made in Japan by Taiyo Yuden. Most people recommend the Japanese media.
DVD-R: I've only used yellow-top Maxells (MXLRG02 & TYG01) in my M10S. No coasters yet.
DVD-RW: Maxell (TDK502) and Memorex (RITEKW01) have worked fine for me.
DVD-RAM: No problems with TDK (MXL7).
Don't use Optodisc, bad spots that you won't know are there till playback. 180 + Prodiscs I haven't had a problem yet, and they only cost about 40 cents apiece in lots of 100. Those are both DVD-R.
DVD-R = MXLRG02, TYG01, PRODISCS03
DVD-RW = TDK 2x, RITEKW 1x, PVC 1x
DVD-RAM = PANASONIC
www.nomorecoasters.com still appliesAnswers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Best and worst DVD+R DL media
By Persistence in forum MediaReplies: 22Last Post: 25th Sep 2011, 18:16 -
JVC DR M10S, DVD-RW 4X, Media
By pepegot1 in forum MediaReplies: 6Last Post: 27th Mar 2009, 08:21 -
Best way to store DVDR? Worst?
By ImSeeker in forum MediaReplies: 25Last Post: 12th Sep 2008, 19:29 -
Worst DVD media ever - Courtesy of CircuitCity
By SingSing in forum MediaReplies: 36Last Post: 13th Jun 2008, 03:20 -
Worst DVD Ever
By videobread in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2008, 22:28
