  1. I WAS WONDERING IF YOU CAN COMPRESS A MPEG1(VCD FILE) TO MAKE IT SMALLER? I HAVE A FILE A BIGGER THAN THE CD CAN FIT AND I DON'T KNOW IF IT WILL FIT OR NOT..PLEASE REPLY..THANKS
  2. hey, you managed to ask the same thing in two different forums..
    CAN SOMEONE HELP ME WITH THIS QUESTION? I GOT A MOVIE THAT IS BIGGER THAN 740MEGS..PLEASE HELP ME OR IF THERE IS A PROGRAM I CAN GET THAT WOULD HELP MAKE THE SIZE SMALLER CAN YOU ALSO POST HERE..THANKS A BUNCH.
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  3. But anyway, go to the tools section, under templates (for TMPGEnc) use Sefy's Templates to convert.
    i wouldn't recommend recompressing an mpeg file... it's gonna look blockier than before.
    They'll do real well for that if you configure them a little more, or buy bigger cd's.
    _________________
    Erik M.
    <font size=-1>[ This Message was edited by: Riot_Inc on 2001-07-13 16:12:40 ]</font>
  4. what would you recommend then..what do you mean configure them(sorry i am a newbie).
    <font size=-1>[ This Message was edited by: jupiter172 on 2001-07-13 16:13:33 ]</font>
  5. if you don't have the original source (assuming you converted from another format), get a bigger cd. if you have the original, reconvert... or get a bigger cd.
    just tweak the settings a little... just lower the bitrate for somethings, like the audio or something
    Overburning is another option, but you got that on your other topic (although i wouldn't go for that either..)
    _________________
    Erik M.
    <font size=-1>[ This Message was edited by: Riot_Inc on 2001-07-13 16:15:58 ]</font>
    <font size=-1>[ This Message was edited by: Riot_Inc on 2001-07-13 16:24:41 ]</font>
  1. DVD Shrink doesn't compress, How can I compress a MPEG2 File
    By happydog500 in forum Newbie / General discussions
    Last Post: 28th Jun 2005, 13:28
  2. How to encode regular MPEG1 mpeg file to compress
    By brumans in forum Newbie / General discussions
    Last Post: 25th May 2003, 23:31
  3. How can I shrink 780Mb MPEG1 to 700Mb MPEG1 for burning VCD?
    By MachineMan in forum Newbie / General discussions
    Last Post: 11th May 2003, 15:31
  4. Replies: 8
    Last Post: 19th Jun 2002, 23:45
  5. Replies: 0
    Last Post: 1st Dec 2001, 21:39
DVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial!
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
