VideoHelp.com Forum
  1. I am trying to author a dvd with nero, I put all files into the Video_TS folder as supposed to, but when I burn, I get an error stating this:
    VTS_05_0.BUP needs to be identical to VTS_05_0.IFO
    Is there a way to fix the files so they will become proper to burn? Or any other suggestions? Thanks in advance!
  2. Where do these two files come from?
    You made them up?
  3. Member yoda313's Avatar
    Hello,
    I use roxio to burn my video_ts folder and I've never run across that error. Are you burning as a data dvd? You should be able to just put the video_ts folder as the only directory in the dvd (ie d:\video_ts). Do you have another burn program? Try something else.
    Kevin
    P.S. Here's an idea, why don't you copy the .ifo file and overwrite the .bup file? That would make it identical! Of course, backup the .bup to a floppy if that doesn't work.
  1. How to rip DVD's: Image File or VIDEO_TS-Folder
    By flashandpan007 in forum DVD Ripping
    Last Post: 9th Feb 2010, 10:08
  2. Burning DVD with VIDEO_TS Folder
    By bguguen in forum Mac
    Last Post: 28th Jul 2009, 00:10
  3. Avi->DVD no Video_TS folder
    By gaikoku in forum ffmpegX general discussion
    Last Post: 13th Sep 2008, 12:11
  4. Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
    By MacPCConsultants in forum Newbie / General discussions
    Last Post: 28th Nov 2007, 06:16
  5. VLC - plays DVD from video_ts folder?
    By qpskfec in forum Software Playing
    Last Post: 21st Nov 2007, 13:38
